Are Madmapper sending OSC information?
  • fekril
    by fekril » Thu Nov 24, 2016 7:33 pm
    Ok to receive, but I can not find how to send it
    I'm trying to do this with VEZER, it works with other software like Resolume, but Madmapper does not seem to send osc.
    I Looking o/c on my computer with OSC DATA MONITOR imposible do see anything.
    Are Madmapper realy able to send OSC information?
    Re: Are Madmapper sending OSC information?
    by mad-matt » Thu Nov 24, 2016 10:51 pm
    MadMapper sends OSC for all assignments you created (see all in Controls dialog / OSC). For instance if you map OSC address "/toto" to "/surfaces/Quad 1/opacity", then when you change the opacity, MM will send the value on OSC address "/toto".
    This is used for feedback. You have to specify the OSC feedback port in MM Preferences / OSC.
    The default behavior of MM (OSC feedback mode "Auto") is to send OSC feedback to all OSC clients that sent any OSC message to MM. So MM keep the list of IP addresses from which it received OSC and will send feedback to each of those. You can also specify a custom IP address where MM should send OSC feedback (also in MM Preferences / OSC).
    Does it help ?
  • fekril
    by fekril » Fri Nov 25, 2016 12:54 pm
    ok ok, OSC out must be patched with the famous "Control List", Thank's :D
    by mad-matt » Fri Nov 25, 2016 7:20 pm
    Yes, we don't automatically send all changes in OSC. There are many conrols on each surfaces, when changing presets it would send hundreds of messages. It could be tested though, that might not be a problem...
  • fekril
    by fekril » Sat Nov 26, 2016 12:40 pm
    Yes it's good choice.
    On the other hand I try your example with VEZER, and it record's OSC address "/ toto", but Madmapper does not understand it when it is returned. It seems to react only for "/ surfaces / Quad 1 / opacity".
    I made these tests on betaRC2.
    by mad-matt » Sun Nov 27, 2016 10:00 pm
    Are you sure you selected MadMapper as the output of the OSC Value track ? I just checked and at first I thought it doesn't work because by default ezér assigns the output to "Vezér OSC Output 1"
  • fekril
    by fekril » Wed Nov 30, 2016 3:52 pm
    Yes I'm sure
  • .lov._
    by .lov._ » Wed Nov 30, 2016 4:27 pm
    That does not really matter if MadMapper's OSC input using the same OSC port as "Vezér OSC Output 1" - Vezér using port 8000 by default, as far as I know MadMapper using the same.
    Just did a small test on my side, but seems to working on my side: https://www.youtube.com/watch?v=x551b0W ... e=youtu.be
    Vezér - timeline and control software for visual artists
  • fekril
    by fekril » Thu Dec 01, 2016 3:46 pm
    your link is a private video. :roll:
  • .lov._
    by .lov._ » Thu Dec 01, 2016 4:08 pm
    Ooops, sorry - it should be okay now.
  • fekril
    by fekril » Thu Dec 01, 2016 4:44 pm
    NICE ! :D
