Giving possibility to turn v-Sync off in MadMapper
  • krokoO
    by krokoO » Sun Nov 27, 2016 1:36 am
    Would it be possible for MadMapper to have a user preference, where one could turn v-sync off.
    Currently it is not possible to run an app faster than display Hz if that app publishes data via Syphon Server, and there is a client, that listens to the Server and has V-sync on.
    By being possible to turn v-sync off in MadMapper (which is working as Syphon Client), user could run application (that exports Syphon) at desired frame rate (above display Hz).
    Related thread: https://github.com/Syphon/Syphon-Framework/issues/36
    kroko
    vade
    Re: Giving possibility to turn v-Sync off in MadMapper
    by vade » Sun Nov 27, 2016 2:24 am
    Post to subscribe to thread.
  • krokoO
    by krokoO » Sun Nov 27, 2016 2:24 am
    In the mentioned thread in Github I added a test, that shows that indeed, if Client has v-sync off, then the app that is used as Server can do more calculations per second while still sending data to Client.
    by mad-matt » Sun Nov 27, 2016 3:51 pm
    Ok. It will be possible in 2.6. If you want a pre-version, send me a PM.
    You'll have to enter that in Terminal:
    defaults write com.garagecube.MadMapper doubleBufferredPreview 0
    defaults write com.garagecube.MadMapper doubleBufferredOutput 0
    When a Syphon input is used, MadMapper will try to render as soon as we receive a "newFrameHandler" notification from any Syphon server used (since we can use multiple Syphon streams at the same time). So it should be clean.
    Can you send a QC patch publishing a Syphon at high FPS ?
