Locked 2 posts Page 1 of 1
uv_scale as 2 parameters from remote inputs
  • Videometry
    by Videometry » Wed Nov 30, 2016 7:16 pm
    Any chance you guys could make the uv_scale parameter receive two inputs instead of 1? Basically so that it mirrors the "input size" values for the surface? It's this way for input position (uv x, uv y) but I can only figure out how to scale the input as x and y simultaneously (uv_scale) when its thru a remote input.
    Trying to update surface input positions from a lighting desk to essentially add some gradual motion to these values... Did i miss another way to accomplish this?
    New beta is impressive! Thanks so much for your hard work on Madmapper!
    Dustin
    Re: uv_scale as 2 parameters from remote inputs
    by mad-matt » Wed Nov 30, 2016 10:11 pm
    Thanks for your feedback. There is a technical reason why you can't change separately UV scale X & Y but this could be done with some changes. I added it to the whishlist.
    Always glad to see people exploiting DMX control from lighting desks. So much to do with those...
    Cheers !
