Update MiniMad over network?
  • ProjectileObjects
    by ProjectileObjects » Thu Dec 15, 2016 11:41 pm
    I noticed that if the MiniMad is plugged into a network that you can access it through SSH (thanks to splash screen change in previous thread). Is there going to be a future option to update the MiniMad card and content over ethernet in a future version?
    Thanks, just curious.
    Re: Update MiniMad over network?
    by Pierre Guilluy » Mon Dec 19, 2016 10:17 am
    It's possible to export to miniMAD through LAN, that's actually the way I'm using it for development and testing.
    As for the splashscreen it's a bit hacky but it may turn to a proper feature in the future.
    First, the miniMAD must be running and connected through ethernet to the same network as your computer so you can access it through SSH (the miniMAD IP-address appears on top left of the screen when pressing YELLOW while holding BLUE).
    Let's assume your miniMAD is started and its IP-address is 192.168.1.12
    - In the Terminal
    copy/paste/edit the following line to kill the miniMAD application:
    ssh pi@192.168.12 "sudo killall -9 mad_raspi"
    (type "raspberry" when asked for a password)
    - In the Finder
    press Cmd+K to bring the "Connect to Server" window.
    copy/paste the following line in the "Server Address:" input-box:
    afp://pi@192.168.1.12
    Your miniMAD's "MINIMAD" volume should now be accessible on your Mac.
    When opening the "export to miniMAD" dialog in MadMapper, and you should see the miniMAD's SD-card available for export.
    You can now export your mapping the same way you usually do.
    - Back to the Terminal
    copy/paste/edit the following line to to reboot the miniMAD, hopefully playing your new mapping:
    ssh pi@192.168.12 "sudo reboot"
  • gnomalab
    by gnomalab » Sun Feb 19, 2017 5:29 pm
    cool, works perfect. thanks for the trick.
  • TheYouth
    by TheYouth » Thu Feb 23, 2017 3:26 pm
    Thanks for that Pierre!
    Great to see that there is a way to do it.
    Hopefully this could be implemented to MadMapper in the near future :)
  • evo
    by evo » Mon Oct 23, 2017 6:40 pm
    Is it possible to upload files from a remote location, not the same network, but via the web?
    envisiOn mOre
    by Pierre Guilluy » Tue Oct 24, 2017 5:41 pm
    I guess you can open the necessary network ports on your router and forward them to your miniMAD, and either use a fixed IP address or a dyndns service on your internet connection.
    by Pierre Guilluy » Tue Nov 17, 2020 10:53 am
    Here's an updated version of the procedure using MiniMad 4 on Mac:
    Let's assume your MiniMad is started and its IP-address is 192.168.1.12
    - In the Terminal
    copy/paste/edit the following line to kill the MiniMad application:
    ssh pi@192.168.12 "sudo killall -9 MiniMadVideo"
    - In the Finder
    press cmd+K to bring the "Connect to Server" window.
    Your MiniMad's "MINIMAD" volume should now be accessible on your Mac.
    When opening the "Export Video Mapping to MiniMad" dialog in MadMapper, and you should see the MiniMad's SD-card available for export.
    copy/paste/edit the following line to to reboot the MiniMad, hopefully playing your new mapping:
    by Pierre Guilluy » Tue Oct 05, 2021 10:43 am
    MiniMad remote-export has officially been introduced in MadMapper 4.2.
