Text Generator MM2.5 add new fonts?
    mousejam
    by mousejam » Fri Dec 23, 2016 8:37 pm
    Does anyone know if there is a way to add more fonts to the MadMapper 2.5 TXT Generator (text generator) and also I noticed that some of the fonts on my Mac appear and some do not, some work in the generator and some do not, does anyone know why ?
  • LaurentNovac
    Re: Text Generator MM2.5 add new fonts?
    by LaurentNovac » Mon Dec 26, 2016 12:05 pm
    Hi !
    Merry Christmas !
    To install a new font you can simply put it in the system Fonts (not the user) folder -> /Library/Fonts/
    This is where all your system libraries are installed.
    The font file must be in ttf format, this is maybe some of your fonts are not displayed (or a matter of character set supported by the font).
    If you don't have your font in the ttf format, say you have it in otf, there are a lot of converter on the web.
    Like this one: https://everythingfonts.com/otf-to-ttf
    We could list the user library folder as well, i will add that to our wish list.
    bests,
    Laurent
