Problems with BMD Ultrastudio Recorder
  • DGloudemans
    by DGloudemans » Wed Feb 08, 2017 6:47 pm
    Hello fellow Vj's
    Since a week I got a Blackmagic Design Ultrastudio Recorder. But I have a few issues with it. It seems like it just won't work on Modul8 on my Mac Pro. When setting the input device it just gives black screen. I already tried to run it in different applications and on different systems. On my Mac Pro the capture device works fine in the black magic software and in madmapper. I also tried to run the capture card on my MacBook Pro, where it just works in both modul8 as Madmapper.
    I have checked all the settings, they are on both Mac's the same, I'm also running the same Modul8 versions (2.9.2) and the Macs both run the OS X 10.11.6 with the latest updates installed. I just can't find the problems. Like I already said, in Madmapper everything just runs fine, so I can work around the problem for now, but I would like to just run the input in modul8 for smaller purposes.
    The specs of my Mac's are as follow:
    Mac Pro (Late 2013)
    - 3,5 Ghz 6-core Xeon E5
    - 32 GB 1866 Mhz Ram
    - 256 Gb SSD
    - 2x Firepro D7000 6144 MB
    MacBook Pro (Late 2013)
    - 2.0 Ghz Quad Core i7
    - 8 GB Ram
    - 256 Gb SSD
    - Intel Iris Pro 6100 1536 MB
    I hope someone has the answer for me!
