Motion JPEG A or B? what is the difference??
  • komunikator
    by komunikator » Fri Jun 23, 2006 5:42 am
    after trying out different kinds of compression formats the best results i got in the end were from Apple Motion JPEG A and
    Apple Motion JPEG B. i kept in mind all the usual compromises: size, quality, performance.
    what i dont know about is the difference between these two codecs, if there is one. as far as i can tell they look the same in comparison and size seems to be about equal.
    does anyone here has any experience with these compression
    formats and any info about the difference between A and B?
    yves@garagecube
    by yves@garagecube » Fri Jun 23, 2006 9:06 am
    Here is a description:
    Motion-JPEG (M-JPEG) is a variant of the ISO JPEG specification for use with digital video streams. Instead of compressing an entire image into a single bitstream, Motion-JPEG compresses each video field separately, returning the resulting JPEG bitstreams consecutively in a single frame.
    There are two flavors of Motion-JPEG currently in use. These two formats differ based on their use of markers. Motion-JPEG format A supports markers; Motion-JPEG format B does not. The following paragraphs describe how QuickTime stores Motion-JPEG sample data. Figure 3-1 shows an example of Motion-JPEG A dual-field sample data. Figure 3-2 shows an example of Motion- JPEG B dual-field sample data.
    Each field of Motion-JPEG format A fully complies with the ISO JPEG specification, and therefore supports application markers. QuickTime uses the APP1 marker to store control information, as follows (all of the fields are 32-bit integers):
    Quoted from:
    http://www.devworld.apple.com/documenta ... ion_2.html
  • komunikator
    by komunikator » Fri Jun 23, 2006 5:24 pm
    thanks for the info.....do you guys [garagecube] use this kind
    of compression? and if so to what results?
    i'm in the process of cutting up some old footage, black and white, taken from dvds. i'm using MPEG Streamclip to retrieve
    the videos, cut, and compress. i've tried animation, video, sorenson, cinepak, and whatever else Apple has and the best results were from Motion JPEG. when using MPEG 4 compression,
    after loading the same clip on 4-5 layers it'll start being sluggish which is pretty much what happened with a lot of those
    other codecs. do you guys have any other suggestions for best results when using compressed video in modul8?
    i did look at the 'how to prepare your media' post in FAQ section and i am scaling down to 512x384.
    thanks in advance_
    by sigmasix » Sat Jun 24, 2006 3:09 pm
    In the FAQ they suggest Photo-JPEG, it's what I use and it's good solution 8)
  • komunikator
    by komunikator » Sun Jul 02, 2006 6:58 pm
    yes, photo-jpeg seems to be better at compressing.
    thanks for the info_
  • zamara
    Re: Motion JPEG A or B? what is the difference??
    by zamara » Tue Feb 23, 2016 9:43 am
  • haseem alam
    by haseem alam » Tue Nov 05, 2024 12:20 pm
    Motion JPEG A supports markers like APP1, which helps store control information, while Motion JPEG B does not. This difference may not be easily noticeable in terms of video quality, but it can impact how the video is processed or played back in certain software.
    When working with different compression formats, I found that using a reliable jpeg compressor tool, which helps a lot in maintaining image quality while reducing file size.
