conect reaper to madmapper
  • fredziko
    by fredziko » Mon Mar 20, 2017 2:59 pm
    I'm doing a show and i need to sync the madmapper with the artist backing tracks program (reaper) that sends smpte signal , how can i sync this with madmapper?
  • Kencapr
    Re: conect reaper to madmapper
    by Kencapr » Fri Aug 04, 2017 9:37 am
    Insert the provided SD-card in your computer using the bundled microSD card adapter. If necessary, update miniMAD as advised before exporting.
    Then, select the projector you want to export to miniMAD, adjust the output resolution, the audio output, the playback options, optionnaly unselect and reorder your medias and highlight the default media to be played at startup.
    Finally, click the “Export” button to start the export – FFmpeg Tools is required to export MadMapper project to miniMAD please download FFmpeg Tools Installer – The process may take some time depending on the number of movie files and their duration. MadMapper will avoid transcoding movie files that are already optimized on the SD-card.
