Exporting several different medias
  • Tripped
    by Tripped » Mon Mar 27, 2017 9:09 pm
    When exporting a project to miniMAD which has multiple media files, it can only export one media on all the different surfaces. When playing the exported file on the miniMAD, all media on the different surfaces are replaced by one of the used media files.
    How can I export a project to miniMAD using multiple videos/media and keep them together in one project, perhaps there is a workaround for this?
    :idea:
    default media.jpeg (154.42 KiB) Viewed 8153 times
  • Sebastien-R
    Re: Exporting several different medias
    by Sebastien-R » Tue Mar 28, 2017 12:16 am
    Hello Tripped,
    Welcome :)
    The miniMAD can only play one video at a time unlike Madmapper which can read several at the same time.
    If you want different videos on different surfaces, you must create one video who contain the other videos and select the surface you want.
    Good luck
    Seb
    :wink:
  • Tripped
    by Tripped » Tue Mar 28, 2017 11:05 pm
    Thanks for your reply!
    When creating the combined video file, should I put the different video files literally next to each other, in order to select the different surface in the input screen (and won't this harm the output resolution)? Or should I put them after each other in a time line (linear) in able to select the different time frames on each of the surfaces?
  • Sebastien-R
    by Sebastien-R » Wed Mar 29, 2017 2:17 pm
    Hello Tripped,
    I join you an example.
    Each colored quads (blue, yellow, green red) can be a different video in a 1920*1080 global video.
    In MadMapper you create a quad for each video. :wink:
    Capture Madmapper
    Capture d’écran 2017-03-29 à 14.12.15.png (129.94 KiB) Viewed 8133 times
  • Tripped
    by Tripped » Thu Mar 30, 2017 9:46 am
    It worked :!:
    I created a single video in which multiple videos are cropped and placed next to each other (as in your screenshot :idea: ) using FCPX and then I was able to export it to miniMAD.
  • Sebastien-R
    by Sebastien-R » Thu Mar 30, 2017 1:38 pm
    Hello !
    Cool :D
    Séb
