Best codec for fast export
  • kyrrelys
    by kyrrelys » Tue Mar 28, 2017 9:23 am
    Hi
    How should I format content to make minimad export as fast as possible?
    K
    Re: Best codec for fast export
    by Pierre Guilluy » Tue Mar 28, 2017 8:25 pm
    Original media codec doesn't really matter since all movies and images are converted while exported to the miniMAD.
    Conversion uses all the cores available on the machine to ensure shortest possible export time.
    Export to miniMAD also features optimizations that prevent movies to be exported twice if untouched.
  • kyrrelys
    by kyrrelys » Tue Mar 28, 2017 8:40 pm
    Hi Pierre, thanks for your reply.
    Just out of curiosity, does original content resolution matter?
    K
    by Pierre Guilluy » Tue Mar 28, 2017 9:13 pm
    Well, the smaller resolution the original file, the faster the encoding.
    So basically if your original file is bigger than 1920x1080 (which is the maximum resolution supported by the miniMAD), you can think about reducing its size prior to importing it into MadMapper to reduce the export time.
  • kyrrelys
    by kyrrelys » Fri Mar 31, 2017 7:08 pm
    Great, thanks!
