Locked 6 posts Page 1 of 1
Problem with Import Fixture from SVG file
  • Franck kouadio
    by Franck kouadio » Wed Apr 26, 2017 3:32 pm
    I am facing problem with madmapper 2.5
    I have updated the software (madmapper 2.5) and now i design a SVG in illustrator to map the strip led.
    The problem is when I imported in madmapper nothing appear in the light interface.
    in madmapper I do that: File->import fixtures then nothing occurs.
    I need help please.
    Regards
    Re: Problem with Import Fixture from SVG file
    by mad-matt » Thu Apr 27, 2017 12:03 am
    We're improving this feature for next release (at least showing error message). To help you: did you make lines in your SVG ? MM Does import only lines objects ?
  • Franck kouadio
    by Franck kouadio » Thu Apr 27, 2017 12:49 am
    Yes i made made the lines in my svg. Even i downloaded the svg you made in your madmapper tutorial but nothing appear when importing in madmapper
    by mad-matt » Thu Apr 27, 2017 2:04 pm
    Which version of MM ? 2.5.1 ?
  • Franck kouadio
    by Franck kouadio » Thu Apr 27, 2017 4:10 pm
    I have the last version of madmapper. I updated on Monday 24 April 2017.
    by mad-matt » Sat Apr 29, 2017 11:45 am
    Have you checked your SVG file in a text editor ? It should have "line" elements. Check this example:
    <svg version="1.1" x="0px" y="0px" width="64px" height="64px">
    <line id="fixture3" fill="none" stroke="#000000" stroke-miterlimit="10" x1="0" y1="0" x2="64" y2="64"/>
    <line id="fixture2" fill="none" stroke="#000000" stroke-miterlimit="10" x1="64" y1="0" x2="0" y2="64"/>
    <line id="fixture1" fill="none" stroke="#000000" stroke-miterlimit="10" x1="0" y1="32" x2="64" y2="32"/>
    </svg>
    You can copy this in a plain text document with name "test.svg" and import it.
