Lockups
  • morph
    Lockups
    by morph » Wed May 24, 2017 12:02 pm
    Is anyone else experiencing random lockups with the current beta?
    Seems like it's not restricted to a certain clip or type as triggering the same loop after a reboot can work perfectly. It more seems to happen when you've had something looping for a while and then try to trigger something from another bank or media set.
    Unfortunately as the app doesn't crash I can't generate a crash report, it just locks up, sometimes after a random period it will start again but then lock up as soon as you try to trigger a loop again.
    Re: Lockups
    by Pierre Guilluy » Mon May 29, 2017 10:38 am
    Are you running modules?
    I fixed a freeze of a few seconds that was happening when a module was using the keyword_connect feature.
  • morph
    Re: Lockups
    by morph » Tue May 30, 2017 7:16 am
    I'm always running modules.
    I assume we will get a new Beta in the next day or 2 so I'll wait and test on that one.
    G
    Re: Lockups
    by Pierre Guilluy » Tue May 30, 2017 5:53 pm
    Beta 12 is online, featuring the fix for the lockup.
