How to erase video-file on miniMAD sd card?
  • evo
    by evo » Sun May 28, 2017 4:18 pm
    Should this not be a basic operation from the mad mappers " export to miniMAD interface" ?
    And how to format the SD card correctly? Is it the Apple PI baker, that does the right thing?
    envisiOn mOre
    Re: How to erase video-file on miniMAD sd card?
    by Pierre Guilluy » Mon May 29, 2017 9:44 am
    There's no need to manage anything by hand on the SD-card.
    MadMapper will manage the files for you by removing the unused files during the export operation.
    Don't try to format the card yourself either.
    You can backup and restore your SD-card using Apple Pi-Baker.
