Locked 2 posts Page 1 of 1
3.0 BETA 1 ArtNet Interface Issues (Win 7)
    DwK Tobi
    by DwK Tobi » Mon Jun 05, 2017 12:11 am
    Hi all!
    I tested the 3.0 Beta 1 over the last couple of days on both Mac and Windows and I have to say that I am really impressed on how well the Windows Version is running.
    Today I tried the DMX Output via ArtNet and noticed some strange behaviour when looking for my ArtNet Interfaces on Windows.
    I tried a setup with an "Enttec Open DMX Ehternet" and a "DMX 4 ALL Artnet Multi PixxControl":
    Fist I used the Multi PixxControl with the IP 2.0.0.40. It shows up, but has the IP adress mixxed up and goes offline after just a few seconds.
    madmapper bug.PNG (39.26 KiB) Viewed 23431 times
    I then tried to set it up manually, but did not get any response from any of my DMX fixtures.
    Next I tried the Enttec interface (IP 2.0.0.84) wich gave me the same results...
    madmapper bug 3.PNG (37.79 KiB) Viewed 23431 times
    I did the same tests on my Macbook and everything worked fine there.
    Bildschirmfoto 2017-06-04 um 23.30.25.png (143.37 KiB) Viewed 23431 times
    Can anyone reproduce this?
    Thanks for bringing MadMapper to Windows!!
    Cheers, Tobi
    Re: 3.0 BETA 1 ArtNet Interface Issues (Win 7)
    by mad-matt » Mon Jun 05, 2017 8:54 pm
    Oh, great feedback ! There's a ntohs or htons missing somewhere (there IP address bytes are flipped).
    Be sure it will be solved in the next beta. For now use broadcast ! (until you use less than 30 universes it work fluently)
