Playlist of multiple synchronised videos
  • Bagnos
    by Bagnos » Fri Jun 09, 2017 12:33 am
    Hello everyone.
    I'm new in Mad Mapper and looking for a solution to following issue.
    I have a list of 12 videos of which each one consist of 3 separate files to be played in sync. I managed to find the solution to sync them using keyboard controls, but is it possible to make a playlist for 3 outputs separately?
    Re: Playlist of multiple synchronised videos
    by mad-matt » Fri Jun 09, 2017 11:27 am
    If you put 3 quad with your movies on 3 projector, it will work.
    If you have a MacPro you can do up to 6 outputs with active adapters.
    If you have a laptop, to do 3 outputs, you will need a splitter (Matrox TripleHead2Go or zotac Mini DiplayPort->Dual HDMI (no more produced however))
    If you want to sync with multiple computers, you should send an OSC channel with the movie position, put all your movies in "PAUSE" and assign an OSC control to "/medias/myMovie.mov/position", if you're not over wifi, the sync works great.
