Datapath FX4
  • rolandino
    Datapath FX4
    by rolandino » Sat Jun 10, 2017 4:21 pm
    it would be cool, if there is a Datapatch FX4, which is recognized as 4K or 3840x2400 display by macOS, that you could have 4x 1920x1080 / 1920x1200 displays in the output destination.
    Similar to the TripleHead.
    Is this possible?
    Regards
    Roland
    Re: Datapath FX4
    by mad-matt » Sun Jun 11, 2017 9:36 pm
    Thanks for the suggestion. Indeed that would be nice. I added it to our whishlist. That's an expansive hardware, but that's great to have 4 Full HD outputs from a single display port...
  • MatteLe
    Re: Datapath FX4
    by MatteLe » Wed Aug 29, 2018 9:54 pm
    Hello Matt,
    is there any progress for this feature? Of cause I can do a workaround with Syphon/Spout chain to get separate display areas. I use this also for layered compositions with the DMX light control, but imho there could be less latency (I know, it is not much) if there would be some sort of internal container solution..?
  • uberraum
    Re: Datapath FX4
    by uberraum » Wed Mar 20, 2019 7:59 pm
    I would be very interested in this too...
