Use Syphon and Material at the same time
  • nodecode
    by nodecode » Mon Jun 19, 2017 12:41 pm
    I would like to use syphon input from Modul8 and Madmapper material at the same time... is that possible? Thanks everyone
    Re: Use Syphon and Material at the same time
    by mad-matt » Mon Jun 19, 2017 1:31 pm
    Sure. Since MadMapper 2.0 you can use as many medias as you want at the same time. You can assign different medias to different surfaces and use blend modes / opacity for mixing. You can also just switch media on one a a group of surfaces (or on all surfaces by clicking the media assign button with Cmd key pressed)
