MiniMad Exporting
  • David_Hall_1
    MiniMad Exporting
    by David_Hall_1 » Tue Jun 20, 2017 1:44 am
    Hi there,
    I purchased a MiniMad through the USA store.
    After installing FFmpeg twice I am still unable to successfully export a mp4 video to the SD card.
    At the "Export to MiniMad" window, after I chose all of the options, I hit export and the progress bar says 0% for a split second and then returns to the original screen with no message.
    However, I have successfully exported pictures and a .mpg video. I have tried multiple resolutions, sizes, and lengths of other video extensions.'
    I have already contacted garagecube support.
    Please let me know what my options are. Thanks!
    Re: MiniMad Exporting
    by Pierre Guilluy » Tue Jun 20, 2017 9:43 am
    What version of MadMapper are you running?
    Did you use any advance option?
    Please send me the mp4 file that fails to export in a PM.
  • David_Hall_1
    by David_Hall_1 » Tue Jun 20, 2017 10:28 pm
    I am currently using MadMapper version 2.5.0.
    No, I am not setting any advanced settings.
    I sent you an email with the mp4!
  • David_Hall_1
    by David_Hall_1 » Fri Jul 07, 2017 2:00 am
    I've updated my Mac to the newest version of 10.8 and now it is working perfectly.
    Thanks Pierre!
