Trouble with external display
  • Rxav17
    by Rxav17 » Fri Jul 14, 2017 12:10 am
    I´m working with mad mapper and connect a external display; all ok. If i open modul8 and send output to Madmapper with syphon, the software invert the displays and then appear de controls on the external display, and the main output on the laptop screen. I looking for all options, but i can´t do it.
    What i´m doing wrong?
    The laptop is a MacbookPro Retina 15" beginning 2013, Madmapper is 1.7.3 and Modul8 is 2.9.2
    Re: Trouble with external display
    by franz » Mon Jul 17, 2017 10:28 am
    Which OS ?
    You might need to configure "Display have separate spaces" in your OS preferences ...
    by Pierre Guilluy » Tue Aug 01, 2017 9:21 am
    Please try to deactivate "Displays have different spaces" in System Preferences --> Mission Control.
