Projector not recognized
  • Maqda7
    by Maqda7 » Wed Jul 19, 2017 9:31 am
    Very new to this and been experimenting a bit with my small ViewSonic PJD 5155L projector (800x600). The problem im having is MM isn't recognizing the projector as an output destination. I tried connecting the projector before opening the program but to no avail. I'd really like to experiment a bit with some stuff in the office before going forward with spatial scanners.
    Also, if this works, would I be able to view my output through the projector? Or would I have to go full screen and have guess work on the positions of my design like now?
    I am using the demo version of MadMapper 3.0.3
    Thank you for your help!
    Re: Projector not recognized
    by Pierre Guilluy » Tue Aug 01, 2017 9:16 am
    Are you using MadMapper on Windows or macOS?
    When MadMapper isn't running, are you able to use the projector as a standard display: see the desktop and mouse cursor?
  • Maqda7
    by Maqda7 » Thu Aug 03, 2017 8:15 am
    On Windows 10 and yes I am able to see use it as standard display. .
    by Pierre Guilluy » Thu Aug 03, 2017 2:04 pm
    Ok, so the projector works as a standard display on Windows but it isn't listed as an output in MadMapper?
  • Maqda7
    by Maqda7 » Thu Aug 03, 2017 2:22 pm
    Yes that is correct.
    by Pierre Guilluy » Thu Aug 03, 2017 2:56 pm
    I'm assuming your projector is directly connected to your graphic card through HDMI right?
  • Maqda7
    by Maqda7 » Thu Aug 03, 2017 4:15 pm
    Yes that is also correct.
    by Pierre Guilluy » Thu Aug 03, 2017 4:34 pm
    Please send a screenshot showing the list of displays in MadMapper.
  • KatieLouise
    by KatieLouise » Fri Mar 06, 2020 7:06 pm
    Is this still an issue?
    My projector isn't being recognised in the drop down menu of the Output Destination and I am using windows
    by mad-matt » Mon Mar 09, 2020 2:52 pm
    Are you sure you "extend to" this display in Windows display settings ? Do they appear as separated screens in Windows or as a copy of the other screen ?
    => https://support.microsoft.com/en-us/hel ... l-monitors
  • KatieLouise
    by KatieLouise » Mon Mar 09, 2020 3:42 pm
    Yeh, ive used projectors before so it was already set up as two separate screens. I'm also having the issue on my mac laptop with a different projector so I am hoping it is something that I am personally doing wrong.
    EDIT;
    On my mac it is working but I still have the issues on windows
  • Antony44
    by Antony44 » Sun Apr 05, 2020 6:15 pm
    Please advise which projector to purchase from these two options:
    VIEWSONIC PJD7822HDL or Acer P1500
    In the first version , assessment of black is very confusing; is it better in Acer?
    I need a clear picture to watch a movie in a white but darkened room from a distance of 2.4 meters and a screen width of no more than 1.6 meters.
    Thanks.
    by mad-matt » Tue Apr 14, 2020 9:26 pm
    It depends on your setup. We don't know all hardware. Other users might help.
    My suggestion, since they are supposed to have the same resolution & lumens & opening, would be to go for the one with the highest contrast (better black), so the Viewsonic one. On the object lifetime I have no idea which is better.
