Remote Keyboard
  • mungle
    Remote Keyboard
    by mungle » Wed Jul 26, 2017 12:59 am
    I need to manage playback and mapping remotely.
    The best solution will be to be connected to my miniMAD:
    - via browser with a page that have some button that will trigger/simulate keystrokes
    or
    - via VNC
    I made some try without success...
    could you help me please?
    PS: bluetooth keyboard aren't a solution.
    Re: Remote Keyboard
    by Pierre Guilluy » Tue Aug 01, 2017 8:59 am
    You can program an Arduino Leonardo to simulate keystrokes in response to Midi, DMX or any other protocol.
  • mungle
    Re: Remote Keyboard
    by mungle » Sat Aug 05, 2017 4:49 pm
    I found a solution!
    FIRST PART :!:
    Here the instructions:
    Open terminal and access to your MiniMad
    Code: Select all
    ssh pi@your.pi.ip.address
    pssword: raspberry
    Code: Select all
    cd ~ sudo apt-get install rpi.gpio wget http://sourceforge.net/projects/webiopi/files/WebIOPi-0.7.1.tar.gz tar xvzf WebIOPi-0.7.1.tar.gz cd WebIOPi-0.7.1 wget https://raw.githubusercontent.com/doublebind/raspi/master/webiopi-pi2bplus.patch patch -p1 -i webiopi-pi2bplus.patch sudo ./setup.sh
    Delete the password to access Webiop web interface
    Code: Select all
    sudo mv /etc/webiopi/passwd /etc/webiopi/passwdOLD
    Create directories and uplad files you can find attached to this post (sftp is the way I prefere)
    Code: Select all
    cd ~ mkdir mmcontrol cd mmcontrol mkdir html mkdir html/img mkdir html/js mkdir html/css
    Edit config file
    Code: Select all
    sudo nano /etc/webiopi/config
    In config file find this line
    Code: Select all
    # Use doc-root to change default HTML and resource files location #doc-root = /home/pi/webiopi/examples/scripts/macros
    comment that line if not alreay commented as above and add this one
    Code: Select all
    doc-root = /home/pi/mmcontrol/html
    Start Webiop with debug
    Code: Select all
    sudo webiopi -d -c /etc/webiopi/config
    You will read a line with an http address like http://192.168.0.100:8000 visit it and you will se the remote web UI
    Everythink should works! :D
    SECOND PART :?:
    From here everything works, now I would like to simulate a keyboard so I can use "crop" and "select media" features
    I tried to add two buttons as test so they can simulate keystrokes. Everything looks right but I'm unable to send any fake keyboard output...to have a try just follow these steps:
    when everything works, open your terminal, login via ssh to your minimad ad launch these commands:
    Code: Select all
    cd mmcontrol/html mkdir macros cd mmcontrol/html/macros git clone https://github.com/tuomasjjrasanen/python-uinput.git cd mmcontrol/html/macros/python-uinput sudo python3 setup.py build sudo python3 setup.py install
    when everything is installed run this command:
    Code: Select all
    modprobe uinput
    If you want to run it at startup:
    Code: Select all
    sudo nano /etc/modules
    and add this line
    Code: Select all
    uniput
    now open script.js (the JS file be careful!!!) and uncomment the commented lines
    save the file and upload it in js folder
    now go to mmcontrol/html/macros and add the script.py (the python file attached to this post)
    relaunch webiop with
    Code: Select all
    Everything should works without issue but the fake keyboard (even if I didn't found any log errors) it doesn't works...you can see in terminal that when you press the 1 or 2 button you get print output but keystrokes aren't sent to minimad.... maybe somone more expert then me could fine a solution?
    PS: If I made some transcriction errors please tell me and I will edit!
    USEFUL LINKS:
    Webiop:
    https://github.com/doublebind/raspi
    http://webiopi.trouch.com/issues/140
    https://forums.connectedly.com/raspberr ... rnet-2884/
    https://github.com/doublebind/raspi/issues/3
    UINPUT
    http://tjjr.fi/sw/python-uinput/
    USEFUL WEBIOP COMMANDS
    EDIT PASSWORD
    sudo webiopi-passwd
    DELETE PASSWORD
    START WITH DEBUG
    START
    sudo /etc/init.d/webiopi start
    STOP
    sudo /etc/init.d/webiopi stop
    STATUS
    sudo /etc/init.d/webiopi status
    RESTART
    sudo /etc/init.d/webiopi restart
    START AT BOOT
    sudo update-rc.d webiopi defaults
    DELETE START AT BOOT
    sudo update-rc.d webiopi remove
    script.py.zip
    PYTHON SCRIPT
    (416 Bytes) Downloaded 832 times
    Files to upload.zip
    Files to upload
    (2.62 KiB) Downloaded 873 times
