leap motion
  • zumassimo
    leap motion
    by zumassimo » Fri Jul 28, 2017 4:06 pm
    Hello to all. I downloaded the demo version of mad mapper. I wanted to know how to connect the leap motion. :?:
    Re: leap motion
    by franz » Tue Aug 01, 2017 9:34 am
    connect via usb the leap motion to madmapper
    start madmapper
    select any parameter of a surface, right click it and select "add custom control"
    then in the control list ( CMD-L or ctrl-L), select leap motion
    Re: leap motion
    by mad-matt » Sat Aug 12, 2017 10:45 pm
    In Preferences / Misc, you have to check the "Enable Leap Motion support". It is disabled by default.
Users browsing this forum: Baidu [Spider] and 36 guests
