Cables for Spatial Scanning
  • paulus
    by paulus » Wed Aug 16, 2017 8:31 pm
    HI,
    I want to set up my Canon camera for use with Spatial Scanning, but not sure how to connect it to the MacPro I'll be using. Is it a simple USB cable into the USB Port or will I need something more hi-tech?
    Also wondered if this was a requirement for Spatial Mapping or whether I can get on my ladder (projector is at height) and take a snapshot as near as damn it and use it as a projector background and experiment over the top of that.
    Thanks
    Paul
    Re: Cables for Spatial Scanning
    by franz » Sat Aug 19, 2017 12:12 pm
    use a simple but good quality USB cable, ideally with a ferrite node on one end.
    No need to climb up the ladder if it is dangerous, SpaceScanning should work within a max 30 degrees angle from the projector.
