Automation of pictures
  • somerwest01
    by somerwest01 » Thu Aug 17, 2017 10:10 pm
    I would like to know if in MadMapper can be programmed or sequenced, since what I take is for example that when I project something I can give it to a key and that automatically I load another frame.
    I do not know if I explain myself
    Greetings.
    Re: Automation of pictures
    by mad-matt » Thu Aug 17, 2017 11:23 pm
    Not at the moment, but if you use a sequencer application like Vezér you can easiely program switching picture on surfaces automatically, with OSC or MIDI control.
  • somerwest01
    by somerwest01 » Fri Aug 18, 2017 12:20 am
    Will there be a windows version? Or any other similar software for windows?
    by mad-matt » Fri Aug 18, 2017 2:22 pm
    Any MIDI sequencer would be fine. Personnaly on Windows I use Ableton Live but I suppose you should find something more minimalistic.
    If you don't want to "program" changing picture, but do it live manually, you can use computer keyboard. Just assign the control "/medias/per_type_selection/next_image" to a computer keyboard key. Pressing this key will then loop into the images for the currently selected surfaces.
