FOR SALE: Set of RGB LED Pixel Balls and LED RGB Pixel Bars
    Trickboxx
    by Trickboxx » Sat Sep 02, 2017 9:30 pm
    Set of RGB LED Pixel Ball Strings for Sale - DMX Control - works perfects with Madmapper >>> 895,00 Euro zzgl. 19% Mwst.
    12x 360° Pixel Ball String
    (Length: 1,95m / 12 Balls with RGB LED each String / In & OUT Connector / Pixelpitch 150mm / Ball Diameter 40mm / 8,4 W / 1 String = 36 DMX Channels / Auto DMX Adressing)
    1x Power Supply with 8 Outputs (max. 320W)
    6x 5m Connection Cable
    8x T-Adapter
    4x DMX Adapter
    4x DMX Terminator
    ______________________________________________________________________________________________________________________
    Set of RGB LED Bars for Sale - DMX Control - works perfects with Madmapper >>> 1650,00 Euro zzgl. 19% Mwst.
    24x LED RGB Bar (Length: 1m, Alu, black / 60 RGB SMD5050 LEDs / 16,2W / 20 Pixel > 60 DMX Channel / Auto DMX Adressing) with Clipholder
    16x Trussholder with Halfcoupler
    8x 5m Connection Cable
    8x T-Adapter
    4x DMX Adapter
    4x DMX Terminator
    Cabling & power supply of both Systems are identical and everything can be combined. Package Deal for both Systems >>> 2365,00 Euro zzgl. 19% Mwst.
    The system can be viewed, tested and collected in Germany. Shipping is also possible for an extra charge.
    Contact >>> info@trickboxx.net
    Website: http://www.trickboxx.net
    YouTube Channel: VJ TBX
  • PhilXu007
    Re: FOR SALE: Set of RGB LED Pixel Balls and LED RGB Pixel Bars
    by PhilXu007 » Mon Apr 09, 2018 6:05 pm
    I want to try to use the ws811 gs8208 spi signal led ball with the Madmapper software,what type of artnet converter will i need ?thx!
