Fixtures CSV Import
  • CRYXCL
    Fixtures CSV Import
    by CRYXCL » Mon Sep 11, 2017 7:19 pm
    (Active Version: MadMapper 3.0.3)
    any Manual for the Fixture Import?
    CSV File Specs would be nice..
    I try to get this csv in madmapper .. no success .. :(
    Always the same Massage about an empty file under MAC CSV Excel Export.
    Normal CSV breaks with Error in line 1 .. :/ (universe;startChannel;startPosX;startPosY;endPosX;endPosY;fixtureWidth;fixtureDefinition)
    So please.. i need some help here.. ;D..
    1;1;0;1;30;1;1;Gen
    1;2;0;2;30;2;1;Gen
    1;3;0;3;30;3;1;Gen
    1;4;0;4;30;4;1;Gen
    Greetz,
    Sebastian (CRYXCL)
    Re: Fixtures CSV Import
    by mad-matt » Tue Sep 12, 2017 1:28 pm
    Remove the first line with the header.
  • CRYXCL
    by CRYXCL » Tue Sep 12, 2017 2:40 pm
    Merci for the quick response.
    I've deleted the Headerline, but I still have the same error messages.
    Some Idea how i can fix it.
    Maybe the File Format? (I try every csv option in office with no success.)
    My CSV Table looks like:
    1 1 0 0.5 30 0.5 1 Gen
    1 2 0 1.5 30 1.5 1 Gen
    1 3 0 2.5 30 2.5 1 Gen
    1 4 0 3.5 30 3.5 1 Gen
    1 5 0 4.5 30 4.5 1 Gen
    1 6 0 5.5 30 5.5 1 Gen
    1 7 0 6.5 30 6.5 1 Gen
    1 8 0 7.5 30 7.5 1 Gen
    1 9 0 8.5 30 8.5 1 Gen
    1 10 0 9.5 30 9.5 1 Gen
    1 11 0 10.5 30 10.5 1 Gen
    can you provide me an example file for research please..
    Kind Regrads,
    Sebastian (CRYXCL)
    by mad-matt » Wed Sep 13, 2017 1:01 pm
    Here is an example. First line can be there
    Fixture Definition Name,Start Universe,Start Channel,StartX,StartY,EndX,EndY,Width
    Generic - 2x1 RGB,0,1,0,0.5,2,0.5,1
    Generic - 2x1 RGB,0,4,2,0.5,4,0.5,1
    Generic - 2x1 RGB,0,7,4,0.5,6,0.5,1
    Generic - 2x1 RGB,0,10,6,0.5,8,0.5,1
    Generic - 2x1 RGB,0,13,8,0.5,10,0.5,1
  • CRYXCL
    by CRYXCL » Wed Sep 13, 2017 4:51 pm
    Hi Mad,
    Sorry - but - i try everything... with no success.
    I don't get it.. and i dont know why.. the Error messages that i got is wrong i think..?
    What CSV Format with ";" or "," (Normal is ";") - you provide the sample with ",". (i try both)
    What does the Error message mean
    - "Failed importing files from file: Error at line 1, column 1, no such fixture definition: Generic - 2x1 RGB".
    I try numbers and text - Everytime the same error message will come up - "no such fixture definition".
    Also your fixture definition provide an Error..?
    Any conversation for that field (String, Num, Float)...??
    TEST 1 - NOK
    Generic - 2x1 RGB,0,0,0,0.5,2,0.5,1
    Generic - 2x1 RGB,0,3,2,0.5,4,0.5,1
    Generic - 2x1 RGB,0,6,4,0.5,6,0.5,1
    Generic - 2x1 RGB,0,9,6,0.5,8,0.5,1
    Generic - 2x1 RGB,0,12,8,0.5,10,0.5,1
    TEST 2 - NOK
    Also the same with ";" doesn't work.
    I also try Excel Export Formats with (DOS CSV, MAC CSV, Standard CSV).
    An tested sample file would be nice.. because - no manual, no specs, nothing.
    I only found an xcode project at gitHub (Build fails) and an animated gif with an old spec.
    So please can you tell me the trick.
    Kind Regrads,
    Sebastian (CRYXCL)
    by mad-matt » Wed Sep 13, 2017 5:19 pm
    That's exact, the example I sent you uses a "fixture definition" called "Generic - 2x1 RGB". That's a fixture definition I created in my library (2x1 pixel RGB). You don't have it in yours, that's why you get the message: "Failed importing files from file: Error at line 1, column 1, no such fixture definition: Generic - 2x1 RGB".
    The error message is clear in fact.
    Replace it with "Generic - Pixel RGB" and it will work.
    by mad-matt » Wed Sep 13, 2017 5:21 pm
    Generic - Pixel RGB,0,1,0,0.5,2,0.5,1
    Generic - Pixel RGB,0,4,2,0.5,4,0.5,1
    Generic - Pixel RGB,0,7,4,0.5,6,0.5,1
    Generic - Pixel RGB,0,10,6,0.5,8,0.5,1
    Generic - Pixel RGB,0,13,8,0.5,10,0.5,1
    Attached is the file
    test import fixture lines 2x1.csv.zip
    (1.15 KiB) Downloaded 746 times
  • CRYXCL
    by CRYXCL » Thu Sep 14, 2017 7:21 am
    Hi Mad,
    i got it.. finaly..:-)
    It was an couple of issues at my site.
    at first - my excel export comes with (;) - i had to switch my system settings to (,).
    the second one was that i dont get the clue with Fixture Definition Name = Fixture Library Dropdown Field Entrys.
    Now i can start my csv experiments .. :DD
    Big thank you for your help - with my noob questions.
    Merci Merci .. greetz from Bern
    Have a great Day ..
    Sebastian (CRYXCL)
