OSC to Presets does not work
  • balamsoto
    by balamsoto » Mon Sep 18, 2017 9:31 pm
    what is the best practice to control presents
    select a preset via OSC , my attempts so far do not work
    here is my setup.
    maxmsp - send Osc message port 8000
    message to send ( and works from max to other osc apps like osculator )
    /presets/select 1
    on Madmapper I have set the osc port to be 8000
    and can not change presets via osc
    any advice how to change a preset via osc will be really helpfull.
    best
