Full Screen issue
    ghostofelvis100
    Full Screen issue
    by ghostofelvis100 » Wed Sep 20, 2017 12:38 pm
    Back since a February beta release, all versions do not go into full screen correctly on my laptop (13" retina 2013 - i5 - intel iris - Sierra).
    Screen output remains as desktop - only difference is the mouse pointer disappears and the preview panel is disabled. I can shift the mouse around the screen and when I reach the dock or something the mouse reappears and I can switch applications etc. but when I go back into M8 it still remains in 'full screen' ie no mouse. If I then move up to the menu bar the mouse appears and I can then access the modul8 interface, change controllers etc. however we are still in full screen according to the output menu, and the preview panel is disabled. Comes back to normal when hitting command T.
    I always use the syphon output to MM in production, which works fine.
    I've mentioned this before in a thread on a specific release, and Pierre asked for screenshots, but I don't think you'll see anything from them.
    I'm guessing this is something to do with the os? good luck.
    Screen Shot 2017-09-20 at 11.30.37 copy.jpg (202.38 KiB) Viewed 18664 times
    Re: Full Screen issue
    by Pierre Guilluy » Mon Sep 25, 2017 10:20 am
    If it applies, please try to deactivate the following system preference:
    System Preferences --> Mission Control --> Displays have different spaces
    ghostofelvis100
    by ghostofelvis100 » Fri Dec 01, 2017 12:39 am
    Issue fixed in December 2017 beta.
    Thanks.
    I actually missed your response regarding the mission control spaces. Mine IS activated and the full-screen problem remains fixed, but I cannot check back to the previous beta as it is now out of date and also pointless :D
    great work.
