Sync between Macs with OSC?
  • hann992
    by hann992 » Mon Sep 25, 2017 3:25 pm
    Hi all,
    I am deciding which solution to go for with a large video mapping project. I am considering Mad Mapper right now, and I was wondering about sync'ing several Macs to provide alle the outputs that I need.
    I have a Mac Pro with 5 HDMI outputs, but I need a 6th output, which I thought I would do with a Mac Mini. My idea is to use my Mac Pro to trigger my video, and then it also controls the MacMini with (for example) OSC to make it trigger as well.
    Is that possible with Mad Mapper?
    ie. When I trigger the video for output 1 on my Mac Pro, then it also triggers the next clip on my Mac Mini...?
    Any help will be greatly appriciated.
  • balamsoto
    Re: Sync between Macs with OSC?
    by balamsoto » Tue Sep 26, 2017 1:52 am
    hope this helps
    https://github.com/cansik/madmapperapi
    perhaps the the challenge is to get osc over tcp ip
  • hann992
    by hann992 » Tue Sep 26, 2017 10:32 am
