How to correct for time zone differences in MadMapper with the Calendar Extension Module?
  • CaseyJScalf
    by CaseyJScalf » Mon Jan 30, 2023 9:51 pm
    Just getting into using the Calendar Schedule Module / Extension and I am curious how to do the timezones correctly?
    In my test calendar I am using the commands "On" & "Off".
    In the screenshot you can see how the "On" command is set to 5:00 PM and that it is also on the Los Angeles GMT +8:00 timezone.
    However, in MadMapper it looks like the timezone is off by about 7-8 hours... how can this be fixed?
    Obviously I could just shift all the times in the calendar but that would be tricky to keep straight.
    Or maybe there is a setting in MadMapper I am unaware of? Possibly should I edit the .ics file?
    I would definitely value some insight on this. I did not see any mention in the manual: https://madmapper.com/files/08-Calendar%20Scheduler.pdf
    Thank you!
    Screen Shot 2023-01-30 at 12.48.46 PM.png (11.83 KiB) Viewed 4006 times
    Screen Shot 2023-01-30 at 12.46.57 PM.png (6.4 KiB) Viewed 4006 times
    Screen Shot 2023-01-30 at 12.46.53 PM.png (9.5 KiB) Viewed 4006 times
  • CaseyJScalf
    Re: How to correct for time zone differences in MadMapper with the Calendar Extension Module?
    by CaseyJScalf » Mon Jan 30, 2023 9:53 pm
    Here is a snapshot of the .ics code itself. Looks like it represents the timezone in there correctly.
    Screen Shot 2023-01-30 at 12.52.32 PM.png (110.86 KiB) Viewed 4005 times
