Can't play .qtz files(Quartz Composer files) on Modul8 2.9.2 (Mac OS 10.13.4)
  • CHRISHOLIC
    by CHRISHOLIC » Thu Jun 21, 2018 6:57 pm
    Does anyone have information about modul8 ver2.9.2,
    Quartz Composer, and Mac OS 10.13(High Sierra)?
    My situation is like this:
    My rap top has broken (MacBook Pro 15-inch Mid 2012 / OS10.10),
    then I bought new one. (MacBook Pro Retina, 15-inch Mid 2015 / OS10.13.4 pre-installed).
    I didn't use Migration Assistant tool.(it means I didn't copy any data or settings from old machine)
    I downloaded the latest ver. of Modul8 from website(my space page), and installed it.
    Finally I found big problem...
    I couldn't put Quartz Composer files into Modul8.
    I installed X code(the latest ver.) and Quartz Composer.
    But still Modul8 doesn't recognize .qtz files...
    It shows "MEDIA NOT SUPPORTED".
    I asked Modul8 support team about this problem, of course.
    But unfortunately, their answer was not effective...
    I can play .qtz files on Quartz Composer application, Quick Time Player, and CoGe(VJ software).
    But only Modul8 can't play it.
    I have used .qtz files on Modul8 2.9.2 before.
    The only one difference is Mac OS ver.
    Before, my Mac OS was 10.10...
    What should I do for this problem?
    It's very serious problem for me...
    Please help me...
    Thanks,
    CHRISHOLIC
