Need help to decrease video lag
    by The Midi Thief » Wed Feb 27, 2008 11:23 am
    I need some tips how to reduce video lag, meaning the time it takes when something is triggered in Modul8 to when it appears on the projected screen / monitor of whatever final output I might have. I noticed that some stuff takes like half a second to reach the final output while the response in Modul8 is direct. Simple things like a flash on the beat will suddenly get out of sync (with the music) in the final output.
    This is a normal setup for me these days:
    MacBook Pro 2.33 GHz Intel Core Duo 3 GB RAM
    Media loaded on an external LaCie Rugged 7200 rpm Firewire 800 HD.
    Apple DVI->Composite converter
    Edirol V4 Mixer
    Composite RCA cables running from the converter to the V4 and from the V4 to a projector, to a LCD/Plasma monitor or a video splitter.
    I guess cable length and quality can play a part here but was is the biggest time a thief in a setup like this? What can I improve? Are there any software settings I need to change? Would I gain a lot of I switch to a digital video signal? (which mean loosing the V4?).
    by vanakaru » Wed Feb 27, 2008 6:22 pm
    It may be your Edirol. I do not see any lag when MBP is connected to projector. Same with DualHead2Go. I can trigger clips to the beat very well.
    Do you use scan converter to get composite or just Apple DVI to Video adapter? I am not sure if it makes any difference thou.
    by The Midi Thief » Tue Mar 04, 2008 9:56 am
    No scan converter. But I experienced this kind of lag even before the Edirol (which is a fairly new component in my setup).
