miniMAD + MIDI
  • therealmusician
    miniMAD + MIDI
    by therealmusician » Thu Dec 31, 2020 11:12 pm
    I currently use MadMapper, and control it from my DAW (Reason) using an external MIDI instrument --> MadMapper Driver. I use MIDI CC Key presses that I've mapped in madmapper to trigger certain sequences for my DMX LED strip group.
    One problem I have is that playing music from my computer, and then also running MadMapper on my computer creates more chances for a show to get messed up and for things to crash. I've done a few gigs where all my lights just turned off, for example.
    I don't have a miniMAD but I'm considering purchasing one if it would be a could solution to introduce stability into what I'm doing.
    Can miniMAD replace my current setup?
    Re: miniMAD + MIDI
    by Pierre Guilluy » Mon Jan 04, 2021 3:20 pm
    MiniMad support Midi using the microModul8 USB controller for now.
    However, OSC is the way to remote-control a MiniMad.
    Check your DAW is actually capable of sending OSC, and that the MiniMad provides the features you're interested in.
  • therealmusician
    Re: miniMAD + MIDI
    by therealmusician » Mon Jan 25, 2021 7:37 am
    I don't think Reason supports OSC. Do you know of any 3rd party apps that might enable it?
    Re: miniMAD + MIDI
    by Pierre Guilluy » Mon Feb 01, 2021 10:17 am
    If you're working on Mac, you can download MadRouter on MadMapper Yourspace, which should help you to translate Midi signal to OSC.
