99 free loops for Vjing - videoediv.net
  • Vj-Kar
    by Vj-Kar » Mon Jun 09, 2008 5:36 pm
    hi.. here Vj Kar From italy.. finally i've upload another free loop for Vjing.
    original content created by me.
    the link it's the same of ever..
    http://www.videoediv.net
    now the free loop Are 99 (the old 49 + the new 50)
    720x576 codec compression, indeo 5.11 *.avi, and photoJPG *.mov.
    tested them and let me know what you think !!
    byeez from sicily !
  • lamepantallas
    by lamepantallas » Tue Jun 10, 2008 9:14 pm
    cant view them after downloading....
  • incuf
    by incuf » Tue Jun 10, 2008 11:05 pm
    I guess you don´t have de codec.
    Great loops!!!! really nice style.
    cheers
    IncuF
    www.myspace.com/eyeburner
    Ropski
    by Ropski » Thu Jan 22, 2009 3:43 am
    curious about t, just downloaded them :) thkx 4 sharing
  • meiso
    by meiso » Fri Mar 20, 2009 1:03 am
    Why would you use a CODEC that is not supported by any open source decoders, that only works on windows or Mac OS 9??
    You should re-encode these loops in a better CODEC so we can all try them out! :)
    Lo
    by Lo » Fri Mar 20, 2009 2:18 am
    I don't know what's the problem,
    I use those loops for a year, and the work perfectly
  • meiso
    by meiso » Fri Mar 20, 2009 3:27 am
    What system are you using? The CODEC works just fine on WindowsXP, Vista, etc... But on OS X or higher there doesn't seem to be a CODEC for Indeo Video 5, which is the CODEC used for these videos. If there is let me know!! :)
    by vanakaru » Fri Mar 20, 2009 9:33 am
    last time I looked you had possibilities to dl win(indeo) or mac (photoJpg) versions.
    just checked its still there next to indeo in smaller yellow text until you click on it.
    Lo
    by Lo » Sat Mar 21, 2009 3:36 am
    Here you have the loops with a quicktime codec
    http://www.videoediv.net/vj-loop/index-mac.html
  • meiso
    by meiso » Mon Mar 23, 2009 3:54 am
    Some very cool loops in there.
Users browsing this forum: No registered users and 46 guests
