Hi everyone,
I am wondering if it is possible to send out DMXm values out of MiniMad with a help of a usb to dmx plug? I would like to use this plug:
https://www.bax-shop.nl/externe-audio-i ... -interface
Many thanks!
Best,
Zalan
Is there a potential timeline for this or does Enttec need to release something before you can add support for the Open USB DMX?MiniMad doesn't support Enttec Open USB DMX yet.
Not for the moment.Is there a potential timeline for this or does Enttec need to release something before you can add support for the Open USB DMX?
Yes, both models are supported.I'm assuming the DMX USB Pro and DMX USB Pro MKII are both supported?
Even though that looks interesting, we have no plan to add support for such device in the MiniMad software.I know this would require removing the top case and buttons, but would a DMX GPIO ever be supported? https://bitwizard.nl/shop/DMX-interface ... spberry-pi
Both models can be used.Is there a potential timeline for this or does Enttec need to release something before you can add support for the Open USB DMX?MiniMad doesn't support Enttec Open USB DMX yet.
I know this would require removing the top case and buttons, but would a DMX GPIO ever be supported? https://bitwizard.nl/shop/DMX-interface ... spberry-pi doodle cricket
Thanks
