MadMapper 6.0.8 release
    by MADben » Mon Feb 02, 2026 11:32 am
    Hi everyone,
    MadMapper 6.0.8 is out, bringing a bunch of fixes, improvements and additions,
    Free for v6 owners and available here : https://madmapper.com/myaccount/downloads
    MadMapper 6.0.8 Release Notes
    ADDITIONS
    + Added the possibility to rename computer for better identification in the licenses manager
    + Added the possibility to rename license for better identification in the licenses manager
    + Timelines:
    + Added the possibility to export the audio directly in the exported MadLight sequence
    IMPROVEMENTS
    *Timelines:
    *Improved Timeline Export Audio settings
    *Improved marker selection when it overlaps
    *Improved DMX fixture definition selection (selector with search field)
    *Improved rotative selection in preview
    FIXES
    - Fixed application font in case user installed another "Inter" font on his machine
    - In some conductions, when adding a point in mask it could be inserted at a wrong place
    - Fixed creating sliders node for fixture groups
    - Controls to fixture output/x & y + controls to output/width & height in pixels for all surfaces
    - Fixed crash if an audio device is connected or disconnected during MadMapper startup
    - Fixed navigating in the media/resource selector using keyboard
    - Timelines:
    - Fixed audio level transition when fading from a montage to another
    - Fixed updating movies parameters in user interface when changing from scenes / cues / timelines
    - Improved interpolable keyframe display depending on transition mode
    - Fixed "reveal track in timeline editor" for sub timelines tracks in conductor
    - Disable video/laser cursor + object isolation & highlight selection when exporting
    - Fixed drag & dropping non selected cell to timeline player track
    - Fixed possible issue in scheduler (starting playback before moving to zero)
    - Fixed playback issue in montage track is some conditions
    - MadLaser
    - Fixed issue when vectorizing a very small portion of a material
    The MAD team
Users browsing this forum: Baidu [Spider] and 18 guests
