MIDI
  • Bertrandmdeq
    MIDI
    by Bertrandmdeq » Thu Jul 02, 2026 12:02 am
    I would like to know if there is a way to select several DMX devices with only one MIDI channel? or to put a device on several surfaces?
    In my case, I use triangles with LEDs; I want to be able to select all my horizontal bars in one click, then select by triangle or diagonals to vary the effects. the triangles are like a daf-punk 2007 stage triangle with Versa-tubes but home made
    thanks for the help!
  • ProjectileObjects
    Re: MIDI
    by ProjectileObjects » Wed Jul 08, 2026 10:56 pm
    Instead of MIDI you could use the Object Isolation groups to quickly select multiple DMX fixtures.
    To do so, you select the fixtures, then type in a new group name and save it. (Image attached). Assuming your goal is to select multiple layers at a time in different configurations to change them?
    Depending what you are trying to accomplish you could group certain fixtures, and control the groups over MIDI, or depending on your naming structure, you could use OSC Query / OSC to control multiple things and use a Macro module to control various parameters across them.
    Hopefully, this helps.
    Screenshot 2026-07-08 at 4.51.34 PM.png (8.17 KiB) Viewed 1296 times
