MM 6.1.3 ProRes problem in Input panel
  • Igalvideo
    by Igalvideo » Fri Jul 17, 2026 5:02 pm
    I have a problem with clips in ProRes Codec. They are only visible in the output panel, not visible in input panel.
    I do not have this issue with H264 clips, still images, Syphon or live camera input, only with ProRes clips.
    The issue is the same on both computers.
    Running MM 6.1.3 on MacOS 26.5.2
    Thank you in advance for any solutions.
    Re: MM 6.1.3 ProRes problem in Input panel
    by mad-matt » Thu Jul 23, 2026 1:35 pm
    Indeed. We'll solve that asap. For the moment please disable "Use Hardware Acceleration" option.
  • Igalvideo
    by Igalvideo » Tue Aug 04, 2026 1:43 pm
    MM 6.1.5 solved the issue,
    thank you very much for fast reaction,
    have a nice day,
    L
