When I add the Mediapipe module in MM and go to Setup inside the module I get "No Camera Frames yet" and most of the Parameter UI does nothing. I set the camera to "Integrated Camera" and the camera is working in the rest of MM.
I get face_landmarker.task not found or pose_landmarker.task not found in the Mediapipe Setup. I tried installing Pyston and Mediapipe locally but this made no difference.
There is UI to send to OSC, but not clear how you would use the OSC data to draw say Laser lines.
How is it supposed to work?
