MadMapper 6.2.0 Beta 2 release
    by MADben » Fri Oct 16, 2026 4:52 pm
    Hi beta testers,
    MadMapper 6.2.0 Beta 2 is available, free for v6 owners : https://madmapper.com/myaccount/downloads
    Featuring many improvements and fixes, don't use it for production yet, but we would be happy if you could test it and send us your feedback ! Thanks!
    Happy mapping ;)
    The MadMapper team.
    MadMapper 6.2.0 Beta 2 Release Notes
    IMPROVEMENTS
    * Output parameters can be controlled (through Controls) & Cued (eg start/stop fullscreen)
    * TouchDesigner license is now being checked prior to loading a tox file
    * Added supported filetypes filtering in media import dialog
    FIXES
    - MediaPipe was not finding models on Windows
    - Fixed possible audio crackles in movie playback with FFMPEG Player
    - TouchDesigner engine was still running when module was deactivated
    - TouchDesigner: fixed momentary buttons behaviour
    - TouchDesigner: fixed certain properties not being possible to use in Show Sequencer
    - TouchDesigner: fixed removed parameters still being displayed after reloading
    - Fixed editing FPS / BPM of a timeline while it’s playing
    - MadTimeline: fixed double clicking on Show Player clip to open
    - Fixed getting alpha when snapshotting a video output (ie in PNG)
    - Fixed crash loading pre 6.0 project file with offline module attributes
    - Fixed mask position when pasting mask copied from quad mask with “attach to” = nothing or input
    - fixed processing engine if a laser lines surface has an offline FX
    - Fixed a few reported crashes, thank you all for the feedback / crash reports!
    - Modules: Show Startup, Show Idle, Show Scheduler and Calendar Scheduler now respect timeline Start Point
    - MiniMad: Fixed exporting several media files with the same filename from different folders
    - Fixed exporting a project when loaded by double-clicking
    - Fixed project backup overwriting other project version's backup file
    - Fixed possible crash after a Space Scanner
