Native ESP32 Support for the MadMapper Firmata Module
  • Guru-U
    by Guru-U » Mon Nov 16, 2026 1:36 pm
    Extending the existing Firmata integration with ESP32 support :!: :?:
    Status quo
    MadMapper allows external hardware to be connected through its existing Firmata integration, for example using an Arduino Uno, for interactive installations and audiovisual performances.
    However, the Arduino Uno is becoming somewhat outdated in terms of its technical capabilities. The ESP32 offers a powerful, affordable and versatile alternative with significantly more possibilities.
    Proposal
    I would like to propose extending the existing Firmata module with native ESP32 support, comparable to the current Arduino Uno integration.
    The goal is to make ESP32 boards just as easy to connect, configure and control in MadMapper as the Arduino Uno, without requiring additional bridge software or complicated workarounds.
    Advantages of the ESP32 :idea:
    - Significantly higher processing power
    - Built-in Wi-Fi and Bluetooth
    - Compact form factor and low cost
    - Ideal for distributed and wireless installations
    Requested Features :arrow:
    - ESP32 as a dedicated device option in the Firmata module
    - Communication via USB/Serial and Wi-Fi
    - Digital input/output control (GPIO)
    - PWM output support
    - Reading analog inputs and sensors
    - Easy pin configuration directly within MadMapper
    - Compatibility with common ESP32 boards and corresponding Firmata firmware
    Summary
    Native ESP32 support would be a valuable modernization of the existing Firmata integration. It would make MadMapper's hardware connectivity significantly more flexible, powerful and future-proof.
    I would be very happy if this feature could be considered for future implementation.
    Thank you :)
    Guru-U (soundwaveILLuminaton)
