I have a latency problem with multiple Epson EB-PU1007W and Dante audio.
The Video is delayed to the audio, so adding frame delay to the video outputs make is worse.
The Source video with embedded audio is perfectly in sync.
All projector settings are fine, so no image enhancement or settings that induce delay.
The only solution I found was setting the Dante-Latency to 10ms and the Asio-Latency to 20ms.
So it would be great to have a madmapper setting ad a global delay to the audio-output.
