Locked 6 posts Page 1 of 1
Can my audio reactive Quartz Composer files work in Modul8?
  • garageRoot
    by garageRoot » Sun Dec 06, 2009 4:31 pm
    - Download the SafeAudioInput plug-in from Kineme.
    - Create a folder in 'Library/Graphics/' and name it 'Quartz Composer Patches.'
    - Put the SafeAudioInput plug-in into the folder.
    It is not necessary to reboot your computer for the plug-in to work.
    The following configurations have been tested:
    - Mac OS X 10.5.7 using Modul8 2.5.8.
    - Mac OS X 10.6.1 using Modul8 2.6.
    lotech
    by lotech » Wed Mar 16, 2011 4:39 am
    Can you explain how we then take advantage of this? Do we need to have Quartz Composer installed? I just tried this without and nothing happened. QTZ files stay unanimated.
    VjKg
    by VjKg » Wed Mar 16, 2011 7:00 am
    I am just assuming here but you have to create a Quartz Composer project that uses reactive audio but now it will work in Modul8 as before it would not.
    lotech
    by lotech » Thu Mar 17, 2011 3:18 am
    Got it. Think we need to have Quartz Composer installed.
    Now I have a very good reason to mess with .qtz
  • PRICKIMAGE
    by PRICKIMAGE » Sun May 01, 2011 8:28 pm
    thx for info
    got audio reactive patches working in M8....they seem very sluggish...ideas?
    anythi9ng more i can do?
    ...sometimes u need a PRICK!
    deepvisual
    by deepvisual » Fri May 20, 2011 1:34 pm
    use vdmx or syphon
