Jumping Midi Values - v2.02
  • 3pin audiovisual
    by 3pin audiovisual » Sat Dec 17, 2005 5:33 pm
    I have recently upgraded v2.01 t0 v2.02.
    When I now use my midi-controller, the midi controller no 0 is assigned to every GUI, as well as the controller number I have turned.
    The result is a GUI that constantly jumps between 0 and the new value I have moved to.
    Is this an issue with the update ??
    If so, how can I download v2.01 again?
    VJFranzK
    by VJFranzK » Thu Dec 22, 2005 2:29 am
    Interesting - this just started? what type is your controller, btw
    I've had a problem for a while... see the MIDI input probs thread down a few from here
    yves@garagecube
    Re: Jumping Midi Values - v2.02
    by yves@garagecube » Wed Dec 28, 2005 3:19 pm
    As far as I know nothing has changed regarding midi between the V2.01 and the V2.02. Anybody else ever saw this problem ?
    Yves.
  • Akira
    by Akira » Fri Dec 30, 2005 9:44 am
    May have something to do with your MIDI controller. Have you updated its drivers too? OS revision? Something? I saw this happen with my Electribes which output that weird mixed MIDI data. I also saw it happening with a shitty Oxygen or something like that.
    VJFranzK
    by VJFranzK » Tue Jan 03, 2006 6:02 am
    I'm happy to report that I've upgraded to a Trigger Finger which works perfectly! 8) Will investigate Electribe in future...
    Here's a feature request -
    could we save multiple "default midi maps" to external files?
    (depending on the occasion, we may be working with different controllers, which map differently...)
    bassballs
    by bassballs » Tue Jan 03, 2006 11:27 am
    Yes please, This would be very usefull :P
    ~ Anders K.
  • jm302
    by jm302 » Tue Jan 03, 2006 6:59 pm
    The easy way around this would be to make a couple of different templates with different MIDI mappings and set your prefs to read each M8 file's MIDI info. I think. (although I do see why you'd want this option :wink: )
    Cheers,
    Justin
    http://www.302acid.com
