Locked 1 post Page 1 of 1
How do I install Modul8 on a 2nd computer?
  • garageRoot
    by garageRoot » Thu Jan 26, 2012 3:57 pm
    If you purchased the basic license you can authorize Modul8 on 2 computers.
    If you want to authorize Modul8 on a 2nd computer simply transfer the software using a hard disk or USB drive, or download it on that the 2nd computer through the yourspace page. Then use your serial number to authorize it.
    You can authorize and de-authorize as many times as you wish within the two computer limit.
    If you will no longer be using Modul8 on a computer you must de-authorize it before deleting it. To do this select from the main menu 'Modul8 > De-authorize Modul8...'
