Micromodul8
    cheveria
    Micromodul8
    by cheveria » Wed Nov 26, 2014 3:11 pm
    Anybody knows is there any (video) tutorial for Faderfox Micromodul8?
    Thnxx.
    Hard labor kills, i just VJ instead.
  • samulj
    Re: Micromodul8
    by samulj » Thu Jul 23, 2015 12:22 am
    This seems to be the only thread about Micromodul8 here, so I'll just post here:
    I'm having problems with the Preset buttons on my Micromodul8. They don't seem to send any data to Modul8. If I change the presets manually on Modul8, the Preset LEDs light up as they are supposed to. I cannot find a way to re-map the presets to the button either.
    Any ideas?
  • samulj
    Re: Micromodul8
    by samulj » Thu Jul 23, 2015 8:47 pm
    Ah, found it.
    Apparently the Preferences > Key/Midi Mapping > FaderFox VJ3 MicroModul support option has to be turned off.
    Sorta counterintuitive, but works.
  • samulj
    Re: Micromodul8
    by samulj » Wed May 11, 2016 9:07 pm
    Is anyone runnning the Micromodul8 through a USB hub?
    I'm using a Mid-2014 Macbook Pro for my live gigs. For some reason the Micromodul8 is the only USB device in my setup that only runs when plugged straight to one of the Macbook Pro's USB ports. I've tried several powered USB hubs (USB 2.0 and USB 3.0) but the setup never runs smoothly if the Micromodul8 goes through one of them. I've settled for a D Link DUB H7 powered USB hub in the end.
