More quad points
  • Harrytwofingers
    More quad points
    by Harrytwofingers » Wed Jul 15, 2015 9:38 am
    In our theatre we have a play now, that utilises two chairs. The chairs are shaped like an inverted U. I would like to follow the example in the tutorial "Sending multiple videos from Modul8 to MadMapper". I succeded in that.
    You can see through the legs of the chair. That means the projection part on the middle of the chair also projects on the backdrop. If i do a mask I get a black square instead on the backdrop.
    If it was possible to have more points on a quad surface I would have solved my problem. Or make a mask that can be turned into a surface.
    Thank you
  • Harrytwofingers
    Re: More quad points
    by Harrytwofingers » Wed Jul 15, 2015 9:59 am
    Haaaa!
    Problem solved. As always.......try and try again. The solution was to create a quad and look at the quad options. There it is .....make a mask in the quad.
    Thank for very cool program.
