New Module - (ir) Sound Reactor
  • Invisible Ray
    by Invisible Ray » Tue Nov 17, 2015 4:26 pm
    I created a module to control layer FX with incoming sound. Check it out, and let me know what you think, or if you have any suggestions. You can also email me at: osx (at) auralfixradio.org
    Module description:
    Easily assign different layer FX to the low | mid | hi sound bands for incoming sound.
    * LOW, MID, & HIGH buttons assign the chosen fx to the current focused layer.
    * Can all be on one layer or on 3 separate layers.
    * Damping slider controls the amount of effect applied; effect level is inverse to damping level.
    * Threshold acts as a gate; sound levels below threshold are ignored.
    * PEAK acts as basic peak meter for incoming signal, helpful for adjusting overall sound level coming in. Enjoy!
  • Invisible Ray
    Re: New Module - (ir) Sound Reactor
    by Invisible Ray » Tue Nov 24, 2015 5:20 pm
    Uploaded v1.5
    • made it a layer contextual module, so all LOW | MID | Hi freq FX can be applied to any number of layers
    • improved damping by applying a curve to the slider values
    broken
    by broken » Tue Nov 24, 2015 9:15 pm
    Working pretty well over here!
    Going to see how well it replaces the Sound Router modules
    cheers
Users browsing this forum: Baidu [Spider] and 16 guests
