Generate video pattern for led controlling
  • marcodallago
    by marcodallago » Sun Jul 10, 2016 1:21 pm
    Hello everybody! I've seen in the project "The Cave" that modul8 can create a video pattern to load directly into MadMapper that controls my led stripes with madlight.
    So here there is my question. Is there a module to do that? Not only b&w content but also RGB one. It could be that easy? Also I need this content to depend on an audio input and to control my video pattern.
    Let me know please how can i do it, maybe a workaround. Thank you :D
    ghostofelvis100
    Re: Generate video pattern for led controlling
    by ghostofelvis100 » Mon Aug 08, 2016 3:36 am
    you can create all sorts of generative content with modul8.
    eg.
    select a test card as a media
    set all subtract colour values (rgb) to 0
    add rgb values to whatever colour you wish
    scale down to a low value
    increase x or y scale really high
    viola - you now have a coloured line!
    add an auto rotate or auto move to animate the line
    or try filters module to get really interesting stuff
    it's possible to 'paint/draw' content onto the output, like with the paint module.
    you can also syphon the mad mapper patterns into modul8 if you wish...
