logical render counter in output ?
    pele2010
    by pele2010 » Mon Sep 05, 2016 11:01 am
    this is a question for future Versions:
    can´t we have the counter for the logical render some where else then in the main output?
    If you feedback the signal through syphon you get to see this numbers.
    And although this can be a graphic element, I would like to be able to disable it or enable it.
    Or find another location for it . maybe below the modul8 Text in the main window.
    Is there a reason for this location?
    thanks Peter
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
